  Visitors: 4620
CAD tip CAD tip # 10740:
How to convert a pyramid made of 3D faces to a 3D solid?
A - answer A pyramid (tetrahedron), box, polyhedron or other 3D geometry consisting of a "watertight" shell of 3D faces can be converted to solid 3D body in AutoCAD with a sequence of commands _CONVTOSURFACE and then _SURFSCULPT. This will convert a "paper" model (shell) to a "wooden" model (volume, solid).
See more in Tip 5019.
ACAD
8.2.2016    4326×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Tip 12717:How to hollow out a 3D solid body in AutoCAD?
Tip 12248:How to remove fillet or chamfer from a 3D solid?
Tip 11387:How to edit large STL files in Fusion 360?
