  Visitors: 5147
CAD tip CAD tip # 8248:
How to convert RFA format to DWG files for AutoCAD?
A - answer RFA (Revit FAmily) is the format of families/blocks of the BIM application Autodesk Revit. Many entourage blocks from the "CAD blocks" section are available for download in the RFA file format.
There is no standalone converter for this format, but for one-time conversion of RFA to standard CAD formats you can use the Trial version of Revit Architecture. It can be downloaded from Download.
Open the RFA file in Revit (e.g. by simple drag-n-drop) and using the menu R > File > Export > CAD formats choose export to the format DWG, DXF or DGN or SAT. You can specify other export options and complete the conversion.
Note: make sure you switch first to the view you want to export (e.g. 3D, plan, elevation, etc.).
RevitACADDWG
5.10.2011    96212×
Prices - CAD eShop:
applies to: Revit · AutoCAD · DWG ·
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 10303:Overview of CAD formats supported in Inventor 2016 (import/export).
Tip 10279:Which formats can be exported from configured models in Configurator 360?
Tip 10097:Multiple applications with the same name in the "Open with" menu - which to choose?
