  Visitors: 5339
CAD tip CAD tip # 11016:
How to copy Revit custom colors to another PC?
A - answer You cen preset up to 16 custom colors in Revit. If you need to transfer this setting to a different computer, or preset it on a newly installed Revit workstation, you can just copy the section [Colors] from the text file Revit.ini.
To copy the setup between PCs, use the following steps:
  1. Close Revit.
  2. Open Revit.ini (in Notepad) from the source computer. Revit.ini is stored in the default folder:
    c:\Users\[USERNAME]\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017\
  3. Copy (Ctrl+C) the section [Colors]
  4. Open Revit.ini on the target computer and paste the section [Colors] to it.
  5. Save and close the file.
Revit
26.7.2016    4916×
Prices - CAD eShop:
applies to: Revit ·
Tip 9962:Revit: long delay after you click on the application menu ("R")
Tip 6262:Disabled rendering after installation of Revit 2009.
