CAD tip # 6898:
Tip 14033: | Clipping blocks, images, curves, xrefs - everything, into any shape |
Tip 13868: | XrefStamp - create a dynamic list of xrefs in your DWG drawing. |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13435: | Bulk setting of layer properties according to the object in that layer. |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
How to influence line spacing in AutoCAD texts?
Missing option "Include when adding sheets" in AutoCAD 2010? « | » Using AutoCAD constraints to clean a drawing.
