CAD tip # 6677:
Tip 14033: | Clipping blocks, images, curves, xrefs - everything, into any shape |
Tip 13337: | How to select blocks by attribute values? (SelByAttr) |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
Tip 11868: | Open just a part of a DWG drawing - layers, views. |
Tip 11835: | Shared Views to your DWG drawings - easy collaboration with collegues and clients. |
Autonumbering of AutoCAD blocks (incremental counter, InsertC) « | » I want to display my drawing the same way it is printed (e.g. black-and-white display of a DWG)
Featuring: DwgTextTranslator translates a series of drawings from one language to another using MS Access. Download a fully functional trial version. |
