Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 12282:
Question
AutoCAD cannot directly dimension a local radius of a spline curve. But you can use the following steps:
  • First explode the curve to arc segments with the command FLATTEN from Express Tools.
  • Now run the Dimension tool and hover on a given point on the curve to display (or draw) a local radius and and center point.
See the video:
If you need a better precision than in FLATTEN, set the variable PLINECONVERTMODE to 1, run the command SPLINEDIT with the option _Poly and specify the precision of the conversion - spline to arc segments.
In the case of spline alignments in Civil 3D you can also use the interactive command "Alignment curvature" (csct_SpiralDyn) from the add-on CADstudio Civil Tools.
ACADCivil
22.6.2019    26610×
Share the tip:
applies to: AutoCAD · Civil 3D ·
Tip 14192:MLfillet - how to fillet multilines in AutoCAD?
Tip 13864:Displaying the curvature comb or radii of a general curve - CurvComb.
Tip 13221:Attractor - snap multiple objects to existing points/vertices.
Tip 13183:Lin2Cyl - bulk conversion of lines to 3D cylinders.
Tip 13040:iLogic - display information about complexity of an Inventor part.
Back    All CAD Tips
Categ:
