CAD tip # 9741:
Tip 13843: | Accented characters (umlauts) are incorrectly displayed in the material schedule on isometric drawing. |
Tip 13796: | PCF file generated from AutoCAD Plant 3D is not compatible with my application. |
Tip 13561: | Beware of "permanently" hidden objects in DWG drawings. |
Tip 13529: | How to redefine the behavior of a standard AutoCAD command? |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
How to use XY coordinates from Excel as polyline vertices in AutoCAD? « | » Size of a saved DWG file grows unexpectedly.
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
