  Visitors: 2407
CAD tip CAD tip # 9412:
How to disable "thick-line" selection preview for window-selection?
A - answer You can setup preview effects for object selection with the command OPTIONS - Options > Selection > Visual effects.
But if AutoCAD does not respond on switching off selection previews and selected objects are always displayed with thick lines, the problem is in the graphics driver. Try its behaviour when you switch off hardware acceleration (see the AutoCAD status bar icon).
ACAD2014ACAD2013ACAD2012
26.8.2013    15719×
Prices - CAD eShop:
applies to: AutoCAD 2014 · AutoCAD 2013 · AutoCAD 2012 ·
Tip 13481:How to clear the list of recent blocks in the palette?
Tip 13337:How to select blocks by attribute values? (SelByAttr)
Tip 13150:How to hatch selected objects including overlays and islands?
Tip 12242:How to increase contrast between a constrained and underconstrained curve in an Inventor sketch?
Tip 11464:How to make a fast Inventor Studio animation without rendering?
