  Visitors: 6599
CAD tip CAD tip # 11515:
How to display the Object snap toolbar?
A - answer If you prefer to have the old Object snap toolbar displayed permanently in your AutoCAD window, you can show it even in newer AutoCAD versions.
Type the -TOOLBAR command (note the "-") and on the "Toolbar name" prompt, enter:
"Object Snap"
(note the double quotes)
Confirm the "Show" option by pressing [Enter]. The toolbar will be be displayed.
ACAD2018ACAD2017ACAD2016LT
6.7.2017    38675×
Prices - CAD eShop:
Tip 13221:Attractor - snap multiple objects to existing points/vertices.
Tip 12836:How to suppress snapping when inserting symbols and families in Revit?
Tip 12705:How to disable osnaps for xref objects?
Tip 12458:How to align/center text and other objects in Fusion 360?
Tip 11998:Double object snap (osnap) - how to align a line between two lines? (geom.constraints)
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
