  Visitors: 8039
CAD tip CAD tip # 11195:
How to download and install an update of Autodesk software - e.g. Revit 2017.1?
A - answer The installation image of an update of your Autodesk CAD software (e.g. Revit 2017.1) can be downloaded from several sources, e.g. after logging in to your subscription account (on subscription.autodesk.com), in the section Product Updates, ...
... or after clicking into the Autodesk Desktop App in the category Revit > Revit 2017.1 Update > Update
After downloading the installation file and launching it, the update process is started. At the end, you will need to restart your computer to complete the update.
Autodesk Revit will then start in the updated version 2017.1.
Video:
RevitACADInvMaxVaultCivil
1.12.2016    5324×
applies to: Revit · AutoCAD · Inventor · 3ds Max · Vault · Civil 3D ·
Tip 13917:Check for concurrently running named licenses (device limit).
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13216:Internal CAM kernel error in Fusion 360.
Tip 13192:Why I cannot see the "My Insights" tips and hints in AutoCAD?
