  Visitors: 3817
CAD tip CAD tip # 9699:
How to draw clothoid in AutoCAD?
A - answer You can draw a clothoide (Euler spiral, Cornu spiral, Track transition curve) - a smooth transition between an arc and a straight segment using the LISP utility KLOT, see www.cadstudio.cz/download. Load it with APPLOAD, start the KLOT command and pick the endpoints of an arc and line. The application will draw the clothoid-transition.
ACADADT
16.2.2014    18889×
applies to: AutoCAD · AutoCAD Architecture ·
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 12543:Drawing perpendiculars from any curve in AutoCAD.
Tip 12479:PkLength - export line lenghts to Excel.
Tip 12350:PkArea - acreage of closed areas from DWG to Excel.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
