  Visitors: 6913
CAD tip CAD tip # 8653:
How to enable or disable Task Pane in AutoCAD Map?
A - answer The Task Pane window can be permanently enabled or disabled by setting the Options in AutoCAD Map 3D.
Run the MAPOPTIONS command and check or uncheck the option "Show Task Pane On Startup" in the "Task Pane" tab (startup options). In the current session, you can switch the Task Pane on and off using the MAPWSPACE command.
In an undocked state you can also control the transparency of the Task Pane palette - right click on its title bar.
Map
28.5.2012    47704×
Prices - CAD eShop:
applies to: AutoCAD Map 3D ·
Tip 14110:Comparison of speed and CPU core usage in CAM operations of commercial and non-commercial versions of Autodesk Fusion.
Tip 12120:Double-click to edit raster images in DWG drawings.
Tip 10408:Autodesk Application Manager reports it has been retired.
Tip 9882:How to disable the Autodesk 360 cloud functions in AutoCAD?
Tip 5063:Using WMS data in Autodesk Map 3D 2007.
