  Visitors: 5477
CAD tip CAD tip # 6713:
How to export AutoCAD tables to international CSV or TXT files?
A - answer By default, AutoCAD offers table export only to a comma-separated CSV file. The CADstudio TAB2XLS utility adds more commands with options for export of AutoCAD table objects (requires MS Excel).
The TAB2XLS command exports the selected table from your drawing directly to the Excel application, wher it creates a new sheet and saves it to the XLS format (single-click export).
The TAB2CSV command exports a drawing table to a text file in the CSV format (comma separated values) in the international format - depending on your Windows locale settings (in many European countries this means using semicolons as value separators and decimal commas instead of points). The CSV file is created in the drawing's folder.
The TAB2TXT command exports data of the selected table to a tab-delimited text file. The TAB2HTM command exports data of the selected table to a HTML table.
Version 1.4 (for 2021 and higher) adds Unicode export, plain text without formatting codes.
You can download the TAB2XLS utility from www.cadstudio.cz/download.
ACADADT
29.5.2009    13042×
applies to: AutoCAD · AutoCAD Architecture ·
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12830:Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs.
Tip 12815:How to fill iProperties into Inventor files from Excel?
Tip 12743:A change in iLogic processing of Excel tables since Inventor 2021.
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
