  Visitors: 6695
CAD tip CAD tip # 12222:
How to find elevation (altitude) of a given point on Google Maps?
A - answer There are multiple methods how to get terrain elevation (height, altitude) but one of them is the web application "Map coordinates converter" here in the Converters section.
Specify the map location by entering its address (or POI name), GPS coordinates, by clicking the "My position" button or by mouse-dragging the Marker in the map and click the "CONVERT" button. In the "RESULT" report, you will see the "Elevation" value of the given point displayed according to the Google Maps mapping data.
Please note this is an interpolated value which does not replace professional surveying methods of obtaining terrain elevations. Precision of this data depends on location but it is only about meters. The Result will give you the local density of points used to interpolate the altitude.
30.4.2019    6476×
Prices - CAD eShop:
applies to: * ·
Tip 13971:What do geolocation codes like 8FWPXFCF+82 or 33UVQ61402434 mean?
Tip 12914:Geo2GPS - GPS or UTM coordinates or web map from any coordinate of an AutoCAD DWG.
Tip 11970:How to find the map coordinate system of a drawing?
Tip 10848:GeoCode with what3words location codes.
Tip 9860:Displaying a DWG including GPS position on a mobile phone or tablet.
