AutoCAD allows to select, assign and transform hundreds of frequently used mapping (GIS) coordinate systems from the whole world, by their name or EPSG code.
For this, you can use either the specialized functions available in AutoCAD Map 3D and Civil 3D, or - sice version 2015 - also a plain AutoCAD and its function GEOGRAPHICLOCATION. If you need to find out, which coordinate system is currently assigned, you can detect it directly in the CAD application's status bar:
This option in the status bar can be enabled in Civil/Map through the command MAPSTATUSBAR with its option Show/Hide. And in AutoCAD through the setting "GIS coordinates" in the hamburger menu "Customize" in the right down corner. This setting is stored in the Registry in HKCU\Software\Autodesk\AutoCAD\R23.0\ACAD-2001:409\Profiles\PROFILENAME\StatusBar\Application\GeoCoordSys (1/0).
Another option for displaying the current coord.system (CS) is the dialog of the mapping command ADESETCRDSYS (N/A in plain AutoCAD):
Under the button "Select Coordinate System" (or through the command MAPCASSIGN) you can find the EPSG code of a given system - search for the name of the CS from the first dialog box:
The next method of listing the name of the current coordinate system is the LISP function in the mapping versions of AutoCAD:
(setq cscode (ade_projgetwscode))
A similar function can be achieved (and also in plain AutoCAD) using the variable CGEOCS. You can also display its content in a dynamic text Field.
Note: the variable GEOMAPMODE carry the current display mode of any map overlay from the online service Microsoft BING.
Featuring: Increase your productivity with our set of add-on functions for AutoCAD Civil 3D CADstudio Civil Tools
