  Visitors: 6929
CAD tip CAD tip # 9574:
How to flip arrows (inside/outside) in selected dimensions?
A - answer Beside the individual flips with the standard AIDIMFLIPARROW command you can also flip AutoCAD dimension arrows in one go.
Download the free utility CADstudio FlipDimArrow2 (see Download), load it with APPLOAD and run the command FLIPDIMARROW2. Select the dimensions and in these dimensions the arrows will be flipped - from outside to onside and vice-versa.
ACADADTCivilACADMMap
1.12.2013    13325×
Tip 6087:Flip dimension arrows - outside extension lines.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
