  Visitors: 4287
CAD tip CAD tip # 7178:
How to create a picture on a wall in Revit?
A - answer If you need to "hang" a picture or whiteboard, stick a poster in a window, create a switched-on TV set, or use another case of applying your texture on a face in a Revit project, you can use the "Decal" function.
The procedure of applying your custom raster image is described in the Revit video #29:
Revit2010
23.1.2010    16246×
Prices - CAD eShop:
applies to: Revit 2010 ·
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Tip 9842:Interactive cloud viewer for 3D CAD data in Autodesk 360.
Tip 8241:An overview of web addresses (URLs) for Autodesk Cloud services and apps.
Tip 7627:Where can I find the common shared Autodesk material library?
Tip 7412:Autodesk Material Libraries 2011 - uninstall.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
