  Visitors: 4956
CAD tip CAD tip # 12644:
How to identify parts and assemblies imported from STEP/IGES?
A - answer How can I find Inventor IPT parts and IAM assemblies which were imported from STEP/IGES? I want to skip them in my iLogic ERP publishing script.
Just test your models (documents) for a presence of the iProperty “Preprocessor“ (STEP and IGES) or “Translation Standard“ (IGES). Warning: for STEP assemblies, this property is set only in the IAM file, not in the components.
So you can e.g. use the following iLogic code with the inquiry:
Dim PV
Try
 PV = iProperties.Value("Custom", "Preprocessor")
Catch
End Try
If PV>"" Then MsgBox("IMPORTED")
Examples of imported models:
how find imports
Inventor
16.6.2020    2152×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13273:Missing options when importing STEP files into Inventor.
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
