CAD tip # 10145:
Tip 12348: | Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit? |
Tip 10319: | Conversion of Revit families to FormIt 360 and back (and SKP to RFA). |
Tip 9698: | Data formats supported in Autodesk InfraWorks 360. |
Tip 9528: | Using Autodesk Fusion 360 as a CAD converter. |
Tip 9180: | CAD file formats supported in Autodesk Navisworks 2014. |
How to load a .CTB file into AutoCAD?
How to use the 3D modeler Fusion 360 in offline mode? « | » Physical units conversion tool in an AutoCAD palette.
Featuring: Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally. Try Excellink 2015 |
