  Visitors: 11092
CAD tip CAD tip # 6762:
How to lower the osnap sensitivity?
A - answer If you want to reduce the responsiveness of object snapping - i.e. enlarge the area, where AutoCAD applies the osnap mode, increase the value of the APERTURE variable.
And vice-versa: if you need to increase the sensitivity, decrease this setting.
You can also use the Options dialog, the Drafting tab, the "Aperture size" setting.
ACADLTADTCivilACADM
24.6.2009    33185×
Tip 13819:Position and docking of the Measure palette in Inventor 2024.
Tip 13333:"Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts.
Tip 13307:How to teach AutoCAD Web app a new command?
Tip 11989:How to dimension an ellipse in AutoCAD?
Tip 11936:Why does AutoCAD display an oblique (skewed) plan view and a red-green crosshair?
