  Visitors: 5264
CAD tip CAD tip # 11652:
How to make a part in a Fusion 360 design partially visible (semitransparent)?
A - answer Do you need to make one part of an assembly in Fusion 360 partially transparent (semi-opaque) to reveal internal structure of the design?
Right-click the respective part in the model or in the browser tree and choose e.g. Opacity Control > 50% in the context menu. This part will be displayed semi-transparently.
Fusion360
19.10.2017    7139×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13923:Resetting the Data Panel in Autodesk Fusion.
Tip 13917:Check for concurrently running named licenses (device limit).
Tip 13641:How do I restore an accidentally deleted file in Fusion 360?
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13571:Web application (FormIt, Fusion, AutoCAD...) is displayed distorted, with incomplete UI controls.
