  Visitors: 4466
CAD tip CAD tip # 11072:
How to make an interference line from 3D Faces?
A - answer How to generate intersection line between two non-complanar 3D Faces?
First convert the 3D faces (3DFACE objects) to surfaces with the CONVTOSURFACE command. Then use the INTERFERE command to generate the 3D intersection line.
In older AutoCAD versions you can also thicken the surfaces (THICKEN) and then INTERSECT them.
ACAD
30.8.2016    2589×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12836:How to suppress snapping when inserting symbols and families in Revit?
Tip 12771:Simplification of an assembly in Fusion 360 - the shrinkwrap function
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 12710:Boolean subtraction of 3D mesh objects in Meshmixer.
Tip 12687:How to find the intersection curve of two surfaces in Fusion 360?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
