CAD tip # 6799:
Tip 13296: | How to correctly load a KML/KMZ file into Civil or Map 3D? |
Tip 13131: | How to crop an image or PDF underlay in Revit? |
Tip 12847: | How to make transparent mask for raster maps in Autodesk Infraworks? |
Tip 12844: | How to import maps from a WMTS source into Civil or Map 3D? |
Tip 12361: | Seamlessly connected images by irregular clipping in AutoCAD (or LT). |
Inventor is not a toy! (a toy animation)
Draping an aerial image on a Civil 3D terrain surface. « | » Rotating viewport contents together with the viewport.
