  Visitors: 5467
CAD tip CAD tip # 11018:
How to map properties from an imported STEP file to Inventor?
A - answer With the new tool "Property Mapping for Imported CAD Data" (available since Inventor 2017 R2) you can easily map properties from CAD files imported from CATIA, Pro/Engineer, Creo Parametric, STEP, NX and SolidWorks to standard Inventor iProperties.
The "Property Mapping for Imported CAD Data" tool can be invoked by:
  • The Property Mapping button at the bottom of the Import dialog box. This button is only enabled if you are importing a CATIA, Creo, NX, STEP, or Solidworks file into an assembly file.
  • By going to Start menu > Programs > Autodesk > Inventor 2017 > Tools.
Inventor2017
26.7.2016    12679×
Prices - CAD eShop:
applies to: Inventor 2017 ·
Tip 14138:How to hide individual block attributes - 3 methods.
Tip 14048:List of disks, CD-ROM drives, USBs and other disk functions for LISP.
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
