CAD tip # 10195:
Tip 13358: | Restore the last deleted entity in the DWG. |
Tip 12237: | UnfoldRS - unfold 3D surfaces to 2D in AutoCAD. |
Tip 11404: | Operations with attributes inside a block - fields. |
Tip 10307: | Easy mirroring of selected objects around their axis/center. |
Tip 9644: | How can I mirror my drawing without mirroring the blocks (symbols)? |
Inventor is slower opening files in older formats. « | » Wrong results when adding or subtracting °C temperatures in Revit.
