  Visitors: 5562
CAD tip CAD tip # 6660:
How to optimize complex 3D models?
A - answer If you need to simplify a complex 3D object formed by a high number of faces, you can use the ProOptimizer tool in 3ds Max (or 3ds Max Design) 2010 and higher.
The optimization of 3D objects can be invoked either through the "ProOptimizer" modifier - for selected objects in your scene, or as a batch optimization tool ProOptimizer, which can simplify in one go all .max and .obj files in a selected folder.
This batch tool can be run from the Utilities panel. Click on the button "More..." and in the list of utilities choose "Batch ProOptimizer". In the panel then click on the button "Batch Optimization" and in the dialog of this utility select he input and output files and a number of parameters controlling the method of optimization.
ProOptimizer
The ProOptimizer tool reduces the number of vertices (faces, polygons) in 3D objects while preserving the object’s appearance. Optimizing objects can reduce a scene’s memory requirements, simplify modeling because objects have fewer faces, and improve the speed of viewport display and rendering time.
max2010
5.5.2009    27007×
Prices - CAD eShop:
applies to: 3ds Max 2010 ·
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 12663:How to transfer my project from Infraworks to Revit?
Tip 12625:How to convert a 3D model from Inventor to VR using 3ds Max Interactive.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
