  Visitors: 8083
CAD tip CAD tip # 8000:
How to remove dimension style overrides from your dimensions?
A - answer If you need to remove (clear) dim overrides applied to the individual dimensions in your drawing, use the command DIMOVERRIDE with its option Clear overrides.
Select the dimension objects and this command changes (reverts) their appearance to the default display defined by their dimension styles - it removes all individual overrides (if any).
ACAD2012ACAD2011ADT
27.5.2011    18770×
Prices - CAD eShop:
Tip 8951:Multicolor dimension texts in AutoCAD.
Tip 8430:How to add/override {} in dimension text or style?
Tip 6239:Overriding dimension text in Revit.
Tip 3832:How to quickly find dimensions with 'hardcoded' dim.text?
Tip 3638:Multi-line dimension texts using control codes.
