  Visitors: 5403
CAD tip CAD tip # 11350:
How to renumber Revit rooms in a given order?
A - answer If you add a room to your layout late in the design process, you will probably need to renumber all rooms on the same level to keep some logic in the room numbering scheme.
Revit does not offer any tool to renumber multiple rooms so you will need to edit the tags one by one. Fortunately, there is a way to automate this workflow and renumber all rooms in one go, along the sketched "walk" curve. Dynamo comes to the rescue - see the attached video and the description on the Czech blog:
Revit2018Revit2017
10.3.2017    7707×
Prices - CAD eShop:
applies to: Revit 2018 · Revit 2017 ·
Tip 11349:How to list Revit room areas by the DIN 277-1 standard?
Tip 11189:Mass rename of spaces (Revit MEP) from rooms in an underlaid architecture model.
Tip 9470:Rooms from Revit projects into Navisworks.
Tip 5334:How to schedule areas of non-closed spaces in Revit?
Tip 4826:Common label for multiple rooms in Revit.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
