  Visitors: 6136
CAD tip CAD tip # 8646:
How to run 3D Anaglyph plug-in in Inventor 2012?
A - answer If you want to use the generator of stereoscopic 3D anaglyphs (see Anaglyphs for 3D) also in an older version of Inventor, take the following steps (can be generalized for most Inventor 2013 plug-ins):
  1. Install the version for Inventor 2013 from Exchange Apps or from the CAD Studio Download page.
  2. Copy the file
    C:\Users\{username}\AppData\Roaming\Autodesk\ApplicationPlugins\CAD Studio Inventor Anaglyph.bundle\Contents\CADStudio.AnaglyphCreatorAddin.Inventor.addin
    to the file
    C:\ProgramData\Autodesk\Inventor 2012\Addins\CADStudio.AnaglyphCreatorAddin.Inventor.addin
  3. Open this file in Notepad or other text editor (not MS-Word!)
  4. Edit the seventh line from
    < Assembly>AnaglyphCreatorAddin.dll< /Assembly>
    to
    < Assembly>C:\Users\{username}\AppData\Roaming\Autodesk\ApplicationPlugins\CAD StudioInventorAnaglyph.bundle\Contents\AnaglyphCreatorAddin.dll< /Assembly>
  5. Save the file.
Note: replace {username} with your profile name in the paths; the XML markup < Assembly> should have no space
That's all. Run Inventor 2012 and the Anaglyph plug-in will be loaded.
Inventor2012
23.5.2012    9275×
Prices - CAD eShop:
applies to: Inventor 2012 ·
Tip 9420:Stereoscopic view modes in Autodesk VRED.
Tip 8630:How to create red-cyan anaglyph from AutoCAD, Inventor or Revit?
Tip 8330:Rendering stereoscopic images in 3ds Max (anaglyphs).
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
