  Visitors: 3635
CAD tip CAD tip # 10321:
How to save a 3ds Max scene to an older format?
A - answer Autodesk 3ds Max since version 2012 can save scenes to older .MAX file format versions. This option ("Save As Type") is offered in the commands:
  • Save As
  • Save Copy As
  • Save Selected
  • Container > Save As
You can save to the following versions:
  • 3ds Max 2012 can save to versions 2010, 2011
  • 3ds Max 2013 can save to versions 2010, 2011, 2012
  • 3ds Max 2014 can save to versions 2011, 2012, 2013
  • 3ds Max 2015 can save to versions 2012, 2013, 2014
  • 3ds Max 2016 can save to versions 2012, 2013, 2014, 2015
3dsmax
17.5.2015    13131×
Prices - CAD eShop:
applies to: 3ds Max ·
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 12779:How to export a hi-res image from Autodesk Infraworks?
Tip 12663:How to transfer my project from Infraworks to Revit?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
