  Visitors: 3837
CAD tip CAD tip # 6718:
How to select all blocks with the same name?
A - answer You can use the QSELECT or FILTER commands to select all blocks with a given name.
But there is also a quicker way - you can use a simple macro which selects all blocks of the same name as a picked block (block reference, Insert). The SELBLK.LSP macro can be found on Download.
Load the LSP file with APPLOAD and then anywhere AutoCAD prompts to "Select objects" just type 'SELBLK (or 'SELBLKS for multiple block names, or 'SELBLKN for typed block names, wildcards).
ACADADTACADMCivil
2.6.2009    22035×
Tip 13158:ScaleBB - scale multiple objects to their ref.points or bounding boxes
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
