  Visitors: 4245
CAD tip CAD tip # 7613:
How to select all dynamic blocks?
A - answer If you need to select (identify) all dynamic blocks (block references) inserted in the current DWG drawing, you can use the SelAllDB command from the SelDB LISP utility.
You can download this tool from Download and load it with APPLOAD.
ACAD
16.10.2010    6327×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13337:How to select blocks by attribute values? (SelByAttr)
Tip 7583:Select dynamic blocks by dynamic properties or visibility states.
