  Visitors: 7266
CAD tip CAD tip # 13337:
How to select blocks by attribute values? (SelByAttr)
A - answer Using the freeware LISP utility SelByAttr, you can easily bulk select blocks determined by the existence or value of a particular attribute or by a range of attribute values.
You can download the SelByAttr app from Download, load it into your AutoCAD using APPLOAD and launch by typing the command SELBYATTR (or -SELBYATTR as the commandline version, or (C:SELBYATTR) directly on the Select objects prompt).
In the dialog box or in successive prompts, specify the name, list (enumeration), or mask of the block names (e.g. Door*,Sliding*), the name, list, or mask of the layers in which the blocks are inserted, the name, list, or mask of the attribute names/tags (e.g., Width), and then the attribute values, if any. You can also pick the names from the drawing with the "Pick" button - by selecting a sample block, resp. attribute.
The searched attribute values can either be entered as text (again, a specific value, enumeration, or mask) or as a number or range of numeric values. This can be specified either by a range from-to or by specifying a value and a tolerance (allowable deviation from this value).
Using the Recalc button, you can view the number of blocks to be selected, a preview of the list of selected blocks and their attribute values. You need to specify at least one search parameter - e.g. "*" as the block name.
The application also supports dynamic blocks. See also the related SelDB application for selecting blocks according to dyn.block parameters.
ACADACADMPlant3DCivil3DMap
21.5.2022    4726×
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13769:Connect points by a list of point numbers - PoNum.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
