  Visitors: 7982
CAD tip CAD tip # 14163:
How to select DWG texts containing a certain number of characters?
A - answer If you want to find and select all texts in your AutoCAD drawing that contain a certain number of characters, you can use e.g. the command FILTER or a LISP add-on application.
In the FILTER command, choose the filter "Text, value" and as the text value, type wildcard characters, e.g. "????". Then select texts using this filter. Only those texts with 4 characters will stay selected.
Another way, with more advanced options, is the LISP add-on app srxText (see Download) for processing regular expressions, and its option Select. After loading the app (APPLOAD), type the command SRXTEXT2 and the following options:
Pøíkaz: SRXTEXT2
Search texts using [Regular expression/Exact string/Substring] : R
Enter the searched pattern: ^.{4}$
Enter the replace pattern ($1$2 for regex captures):
(no replacements will be performed)
Search only in [Layer/All] :
Search only [Selected/All] :
Number of searched entities: 53
yes
Perform [Skip/skipAll/seLect/Exit]? : L
yes
123
big
red
Number of found/replaced entities: 4/0
Just texts with exactly 4 characters will stay selected.
Other examples of regular expressions for this purpose:
^\w{3,5}$
texts with 3 to 5 word characters
^\d{6,}$
texts with 6 or more digits.
Both tools may have a problem with formatted paragraph texts, because their text strings may contain formatting characters and codes.
ACADACADMPlantCivil3DACADE
4.7.2024    708×
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13139:How to insert a new line into multiline text in the Find/Replace command?
Tip 12803:How to add double line-spacing to AutoCAD paragraphs?
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...)
Tip 8065:How to add prefix or suffix to selected drawing texts?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
