CAD tip # 12712:
applies to: Inventor · |
Tip 13211: | Automatic numbering/renaming of multi-volume bodies in a part. |
Tip 13040: | iLogic - display information about complexity of an Inventor part. |
Tip 11983: | How to use iLogic code to fill username into iProperties? |
Tip 9561: | iLogic macro for exporting IDW/DWG Inventor drawings to DXF. |
Tip 9477: | Saving a DWG copy of an IDW drawing named by revision number. |
How to hollow out a 3D solid body in AutoCAD? « | » Boolean subtraction of 3D mesh objects in Meshmixer.
Featuring: Add .CIT raster format support to AutoCAD and Map and Civil 3D CITin ![]() |
