  Visitors: 9127
CAD tip CAD tip # 8427:
How to set the size of camera and light icons in 3ds Max?
A - answer The position and direction (targets) of cameras and lights in the viewports is represented by icons (glyphs). The size of these icons does not depend on the zoom and scale of your scene - remains fixed.
You can control the size of camera and light icons in 3ds Max preferences - Customize > Preferences > Viewports - set the field Non-Scaling object size (default value is 1.0).
3dsmax
19.1.2012    8829×
Prices - CAD eShop:
applies to: 3ds Max ·
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12625:How to convert a 3D model from Inventor to VR using 3ds Max Interactive.
Tip 12040:PaintSelect - select objects by cursor painting - paint selection.
Tip 11303:"Clock Error" when starting Autodesk CAD application.
LogOff 2006 More info
