CAD tip # 12365:
applies to: Inventor · |
Tip 13536: | iLogic: How to find if a document is a sheet metal part and if it contains holes? |
Tip 12416: | How to export DXF outline of unfolded sheetmetal in Fusion 360, with no bending lines. |
Tip 12392: | Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA |
Tip 10916: | How to project unfolded flat pattern to a sketch? |
Tip 10118: | How to export a DXF file with punch points from an unfold? |
Gaps - how to find loose ends on lines in a DWG? « | » Seamlessly connected images by irregular clipping in AutoCAD (or LT).
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools ![]() |
