  Visitors: 4730
CAD tip CAD tip # 6933:
How to show history of drawing entities?
A - answer The order in which the individual drawing entities were created - i.e. their history in time - can be displayed using the LISP utility History.
Xanadu History is a free LISP utility allowing to "replay" the history (order) the drawing entities were created. It is not just a slow redraw. The individual drawing objects are animated in the order of creation time, not in the assigned draw order.
Load the HISTORY.VLX in your AutoCAD session (e.g. with the _APPLOAD command). In a copy of your DWG drawing, run the HISTORY command. It will initially hide all drawing entities. Then the entities will be individually displayed in the order of creation. You can choose automatic (animated) display or single step display on pressing ENTER.
The animation speed can be controlled by the LISP variable "history_delay".
You can download History from Download
ACAD
14.9.2009    21840×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13461:The function (entlast) and the block editor in AutoCAD.
Tip 13358:Restore the last deleted entity in the DWG.
Tip 13246:I can't copy/paste a block from AutoCAD into an Inventor drawing.
Tip 12933:Purging small objects from a DWG drawing - PurgeSmall.
Tip 12755:How to create a polyline with multi-colored segments?
