  Visitors: 7188
CAD tip CAD tip # 12172:
How to show or hide an object in all visibility states?
A - answer When editing a dynamic block employing visibility states, new objects are added by default only to the currently set visibility state.
If you want to add new block geometry (e.g. an attribute) as visible to ALL visibility states, grip-select it, right-click it and from the context menu choose Object Visibility > Show in all states. You can also use the commands BVSHOW or BVHIDE. You can use the same commands also to show/hide selected selected geometry in the current visibility state of the edited block.
ACADLT
20.3.2019    4967×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11896:How to drive dyn.block parameters or constraints from Excel?
Tip 11439:Replace block instances (incl. dynamic) with another block.
Tip 11404:Operations with attributes inside a block - fields.
Tip 10761:Dynamic block attributes do not respect visibility states.
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
