  Visitors: 8607
CAD tip CAD tip # 9810:
How to suppress blueish highlight of selected objects?
A - answer The visual effect of blue "glowing" highlight of selected objects (lines or areas), is controlled by the variable SELECTIONEFFECT. This effect can be disabled (switched off) by setting this variable to 0. You can control the highlight color with SELECTIONEFFECTCOLOR.
For object pre-selection (hover), use the variable PRESELECTIONEFFECT.
In higher versions, see also the variable HIGHLIGHT.
ACAD2017ACAD2015LT2015
5.5.2014    20482×
Prices - CAD eShop:
Tip 13481:How to clear the list of recent blocks in the palette?
Tip 11714:How to assign a RAL color to a DWG object and get its ACI equivalent?
Tip 9972:Create free 3D PDF output files from any CAD software.
Tip 9412:How to disable "thick-line" selection preview for window-selection?
Tip 8465:Objects get selected while moving mouse cursor.
