  Visitors: 8448
CAD tip CAD tip # 9581:
How to suppress welcome screen in AutoCAD 2013/2014?
A - answer If you cannot disable (switch off) the welcome screen displayed after launch of AutoCAD 2013, 2014 and higher, with the checkbox "Do not show", or if you want to switch the screen off before the first launch, you can set this option via Registry.
In the branch (an example, your product ID may differ):
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409
set the key LaunchNFW to 3.
ACAD2014ACAD2013LTADTCivilMapACADMACADE
4.12.2013    15665×
Tip 13735:My initial login to Fusion 360 isn't working.
Tip 11374:How to disable the Welcome screen in Fabrication CAMduct?
Tip 8982:How to get back the Welcome screen? (unchecked Display at Start Up)
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
