  Visitors: 6938
CAD tip CAD tip # 8314:
How to switch Inventor from ribbon to classic UI?
A - answer The user interface in Inventor 2010, 2011 and 2012 can be switched between the default ribbon and the old classic environment with tool panels.
The UI switch can be found in versions 2010 and 2011 in the dialog "Application options": Tools > Application options > Colors - the "UI Style" options - Ribbon and Classic.
This option is missing in version 2012 but you can do the same switch by modifying a Registry key. In:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion16.0\System\Preferences\UIStyle\
change the key InterfaceStyle to 1 (classic interface) or back to 0 (the default, ribbon). The practical usage of this switch is rather limited in version 2012 as it does not anymore contain predefined commands in the individual tool panels (they display as empty in the default view).
Inv2012Inv2011Inv2010
9.11.2011    24446×
Prices - CAD eShop:
Tip 13997:4 methods of 3D orbit in Inventor, with specified pivot.
Tip 13920:Saving your Inventor model in the presentation color scheme (iLogic).
Tip 13911:How to print all sheets at once from Inventor?
Tip 13744:Simple password protection of Inventor documents (iLogic).
Tip 13699:How to synchronize camera orientation in different Inventor views?
