  Visitors: 4072
CAD tip CAD tip # 6024:
How to toggle lineweight display?
A - answer To display or suppress lineweights of the individual line entities, you can either use the LWT button in AutoCAD status bar or the LWDISPLAY variable.
You can ue the following menu macro to toggle lineweight display (a single line):
^P'LWDISPLAY $M=$(if,$(and,$(getvar,lwdisplay),1),$(-,$(getvar,lwdisplay),1),$(+,$(getvar,lwdisplay),1))
You can use the CUI command to define a new Command containing this macro and assign it a new Keyboard shortcut (e.g. Ctrl+Shift+T).
ACADLTADTCivilACADM
15.3.2008    39857×
Tip 12755:How to create a polyline with multi-colored segments?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 11830:How to influence linetype scale or color for hidden edges in documentation views?
Tip 11528:Diagonal line across a table cell in AutoCAD.
Tip 11425:Contour lines on a toposurface are displayed as too thick lines.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
