  Visitors: 5769
CAD tip CAD tip # 8819:
I cannot rotate my DWG model in 3D with SpaceMouse.
A - answer Scene (model, view) tilt, spin and roll in AutoCAD with 3Dconnexion SpaceMouse, SpacePilot (and other 3D mice, controllers) works only in 3D visual styles, not in 2D styles.
Set one of the three-dimensional visual styles - either with the VSCURRENT variable, or with the top left in-viewport control, or in the ribbon View > Visual styles - e.g. to Realistic or Wireframe.
ACAD2013ACAD2012
15.9.2012    11992×
Prices - CAD eShop:
applies to: AutoCAD 2013 · AutoCAD 2012 ·
Tip 13997:4 methods of 3D orbit in Inventor, with specified pivot.
Tip 13887:ClosestPt - the nearest point on another curve
Tip 13793:Sometimes my right mouse button doesn't work in Inventor.
Tip 13466:Did you know that you can use 3D Orbit also in AutoCAD LT?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
