CAD tip # 9051:
applies to: Revit 2013 · Revit 2012 · |
Tip 13800: | Visually compare 3D geometry in CAD and BIM files. |
Tip 13404: | How to import an IFC file in AutoCAD? |
Tip 12355: | Revit support for older versions of the IFC format. |
Tip 12184: | Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD). |
Tip 10923: | Which Autodesk products do support the IFC format? |
How to change the order of attribute prompts?
How to copy new frames and title blocks to other drawings? « | » How to select all anonymous blocks in a DWG?
