  Visitors: 9143
CAD tip CAD tip # 10114:
iLogic tip: returning a value on the True and False conditions.
A - answer Using the following variants of iLogic code you can return different values for the "True" and "False" conditions in your macros - i.e. if a given condtion is met or not met:
'Input data
Dim msg as String = ""
Dim condition As Boolean = True
'Variant #1
If condition Then
msg = "Truth"
Else
msg = "Lie"
End If
MsgBox(msg)
'Variant #2
msg = If(condition, "Truth", "Lie")
MsgBox(msg)
'Variant #3
MsgBox(If(condition, "Truth", "Lie"))
Inventor
27.11.2014    6592×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13884:How to send e-mails with an iLogic macro?
Tip 13852:How to bulk-update all model parameters?
Tip 13744:Simple password protection of Inventor documents (iLogic).
Tip 13611:BOM with multi-line items in Inventor.
Tip 13536:iLogic: How to find if a document is a sheet metal part and if it contains holes?
