CAD tip # 8496:
applies to: AutoCAD · |
Tip 14059: | Import coordinates from CSV files into Fusion profiles. |
Tip 13333: | "Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts. |
Tip 13296: | How to correctly load a KML/KMZ file into Civil or Map 3D? |
Tip 12926: | How to import point coordinates from Excel to AutoCAD? |
Tip 12198: | How to remove duplicate points and COGO points from a DWG? |
Intersection osnap does not find the intersection.
Batch change of page setups and purging in DWG files. « | » How to show who saved the DWG drawing last?
