  Visitors: 5314
CAD tip CAD tip # 8111:
Import of UG NX files into AutoCAD.
A - answer The .prt format of the UG NX software belongs to the list of directly supported import formats in AutoCAD.
The standard command IMPORT in AutoCAD 2012 can import (read) both parts and assemblies in the PRT format from the application UG NX version 3 up to 7.5.
AutoCAD imports all following CAD object types:
  • Assemblies
  • Parts
  • Surfaces
  • Solids
  • Multi solids
  • 2D and 3D wire geometry
ACAD2012ACADM2012
26.7.2011    15743×
Prices - CAD eShop:
Tip 12880:How to import Parasolid 33 files into PowerMill?
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 12069:Unicode and DXF files.
Tip 11018:How to map properties from an imported STEP file to Inventor?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
