  Visitors: 8701
CAD tip CAD tip # 8225:
Integration of foreign CAD data into Autodesk Navisworks.
A - answer The project coordination application Autodesk Navisworks offers not only direct support for Autodesk products but also support of project data from other CAD applications and file formats.
The format NWC (NavisWorks Cache) is used for export of 3D geometry and the associated attribute metadata from non-Autodesk applications. Export of NWC files from other different types of applications is provided by a separate module "NWC Exporter" (see Download), which contains native plug-in modules for 32-bit and 64-bit versions of Autodesk software, for ArchiCAD (9-13), 3ds Max (8-2012), 3ds Max Design (2010-2012), VIZ (2007-2008), Microstation (8, 8i, 9, J).
So it is possible in Navisworks 2012 to combine, analyze and present project data from these applications along with CAD and BIM models AutoCAD, Revit, 3D Plant, Civil 3D, with 3D point clouds and other documents.
NW2012
22.9.2011    6536×
Prices - CAD eShop:
applies to: Navisworks 2012 ·
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13404:How to import an IFC file in AutoCAD?
Tip 12348:Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit?
Tip 11818:How to change resolution of images in the Clash Detective report in Navisworks?
