  Visitors: 4499
CAD tip CAD tip # 10006:
Inventor BOM items are not sorted in the right numerical order.
A - answer Clicking on the Item column in Inventor Bill of Materials does not order the item numbers in the proper numerical order:
BOM (CZ)
To apply to right sorting of BOM items, use the "Sort intems" icon in the BOM toolbar. In the Sort dialog then select "Sort by": Item, Ascending.
BOM (CZ version)
The next "Bill of Materials" dialog and the assembly BOM then uses the proper numerical order of item numbers.
The problem is fixed In Inventor 2015 SP2, resp. already in Update 2 for Inventor 2015 SP1.
Inventor2015
13.9.2014    10547×
Prices - CAD eShop:
applies to: Inventor 2015 ·
Tip 13963:Sum of pipe element lengths in Inventor (iLogic).
Tip 13611:BOM with multi-line items in Inventor.
Tip 13531:Thumbnails have incorrect size after exporting the BOM to Excel.
Tip 12451:How to fill a material or appearance name into part's iProperties?
Tip 11732:How to sort BOM or parts list by part number in Inventor? (iLogic)
